Database Question
Hello All!
I'm trying to read some data from a big data file and I'm using one of the example from the package called "Read All Data". When I run the VI and click Get Data button, it shows the column value but get an error that says ran out of memory. I think this example is great because it reads no problem when the file is small. Is there a way around that I can just pull todays date data or data that has been processed in particular date?
Thanks in advance.
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(2,896 Views)
Accepted by topic author KowdTek
You can wire an optional clause to reduce data, it uses standard SQL querries try using a WHERE caluse
ie 'WHERE Date >... and <...' you can limit the returned data.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,886 Views)
Thanks! Smiley Happy
______________
KowdTek
LabVIEW 2009
(2,865 Views)
