Database Querry error when using # in column name
I am using the Database toolkit to work with a MySQL database.  Some of the columns in the database have names with special characters: Batch# and Employee#.  The database tools give me an error when I try to write data to those fields.  I have tried square brackets around the column name [Batch#] but that doesn't seem to help.  Is there a way to update these fields with the Database tools?
Here is the errror:
Error -2147217900 occurred at Cmd Execute.vi->DB Tools Insert Data.vi->Move to NCP.vi
Possible reason(s):
Exception occured in Microsoft OLE DB Provider for ODBC Drivers, [MySQL][ODBC 3.51 Driver][mysqld-3.23.49-log]You have an error in your SQL syntax near '' at line 1.  in Rec Create - Command.vi->Cmd Execute.vi->DB Tools Insert Data.vi->Move to NCP.vi
Message 1 of 1
(2,517 Views)
