Database Connectivity Toolset
I am running LabVIEW verison 7 and am trying to install the database connectivity toolset. When I
try to install it fails and gives me a message that it requires a LabVIEW version 6 runtime engine?
(2,906 Views)
Thank you for posting your question on the NI forum. this is a known problem, the solution is to download the labVIEW version 6 runtime engine, as specified by the following link:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/8c923cec94cbfa3786256bb9004ee2d3?OpenDocument
you can download the runtime engine from: www.ni.com/downloads
Best regards
Kurt
(2,886 Views)
Hello Kurt
Thanks for pointing me in the right direction. installed the run time engine and could then successfully install the DB toolkit
Thanks again
Regards
Lee
(2,848 Views)
