DataSocket Select URL.vi
Hi Daniel,
I have not found a soluiton yet.
Message 11 of 19
(2,328 Views)
Hi Rasmus,
I have escalated the issue to our R&D department. Will let you know when I hear back.
Best,
Daniel Sjostrom
Applications Engineer | National Instruments
Message 12 of 19
(2,317 Views)
Hi again,
R&D are looking into other ways of doing this, would you kindly answer their questions below:
1) Could you describe the system a bit more as a whole, what you are trying to do?
2) Could you be more specific about what type of URL you're trying to communicate with? Your options would vary depending on the brand of PLC or if it's just a general OPC Server. You may want to talk to the manufacturer of that PLC to see how the list of tags is published and how other applications might connect to it.
Best,
Daniel Sjostrom
Message 13 of 19
(2,308 Views)
Double post, please ignore.
Best,
Daniel Sjostrom
Message 14 of 19
(2,307 Views)
HI Daniel,
Sounds good.
  1. The UI functionality is required as part of a generic application with 50+ users where data logging from OPC DA sources can be configured. The current implementation uses the “datasocket select URL.vi”, which will only allow the user to select one tag. This is not useful when the user has 100 tags to select from the same source.
  2. The URL comes from difference OPC DA sources. We are logging from a range of PLC’s from different manufactures. In many cases it we are using Kepware, KEPServerEX as middleware (https://www.kepware.com/en-us/products/kepserverex/)
Message 15 of 19
(2,302 Views)
Hi Rasmus,
According to R&D, it looks like you can only select one tag at a time without the DSC module.
If you get DSC, you would have access to I/O Servers and other VIs that allow the functionality you're looking for.
Let me know if you have any thoughts or questions on this.
Best,
Daniel Sjostrom
Message 16 of 19
(2,292 Views)
Hi Daniel,
It’s the same conclusion I have arrived at, so it looks like there is no feasible NI solution available.
Message 17 of 19
(2,283 Views)
Hi Rasmus
Technically speaking, the DSC module will solve your issue, but I know that the economical aspects associated with that solution made it a less attractive one for you. If you would like to try the solution with the DSC Module, you could always download the customer Evaluation version.
Best,
Daniel Sjostrom
Message 18 of 19
(2,277 Views)
Same topic, but different subject... has anyone been able to get the DataSocket Select URL vi to work on a labview 2019 runtime system? I'm trying to figure out what system components are needed, beyond just the LV RT engine. Thank you.
Message 19 of 19
(2,164 Views)
