DataSocket Python binding
is there a (perhaps 3rd party) solution to connect to NI DataSocket from Python?
Piotr
(7,569 Views)
A google search turned up this result http://www.evolt.org/node/60276
Hope this helps
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(7,524 Views)
yes - Python has built-in library for sockets.
My questions was more if there was/is a lib that encapsulates NI DataSockets.
BTW: is there a technical description what is it 'under-the-hood' when one accessesa data socket via 'dstp://machine/item'
If I understand correctly dstp uses TCP port 3015, right?
Piotr
(7,520 Views)
Hi Piotr,
There is no encapsulated library that you could use outside of LabVIEW to work with DataSockets. Here is a link to a white paper on how LabVIEW uses datasockets. To answer your question on what port to use, you can use any of the ports not already being used. So port 3015 should work fine as long as nothing else is using it.
(7,508 Views)
What about Measurement Studio?  There are bindings to C#, C++.
(7,505 Views)
You are correct and if you look on page 4 of this document you can see that "The DataSocket API is implemented as an
ActiveX control, a LabWindows/CVI C library, and a set of LabVIEW VIs, so you can use it in any programming environment."
Here you can find the datasocket library for LabWindows\CVI.
You should be able to use the ActiveX controls that are supported by Python to talk to the DataSocket API.
(7,473 Views)
