Data updating as steps in graph when acquired from cDAQ
I am using cDAQ-9185 with NI 9205 voltage module to measure values from sensor. When updating the values in graph, it is continuous but graph appears as steps. Is it the problem because of any data loss, or due to excess of data ?
do_what_you_like
(2,678 Views)
Hi Pranash,
Probably its a problem of your VI!
But you decided to attach some blurry screenshot photos instead of the VI with some default data…
(2,665 Views)
I am acquiring data from daq acquisition vi separately and sending it in LV2G to the main screen. How to send all vi's?
do_what_you_like
(2,662 Views)
Hi Pranesh,
What is "LV2G"?
To send all relevant VIs you just ZIP them. (I hope you are using a LabVIEW project and have put all VIs in a folder together with the lvproj file. This way it gets really easy to ZIP them up…)
(2,657 Views)
