04-14-2011 03:30 AM
Dear All,
My problem is to send data stream from LabView to Simulink (and then results obtained in Simulink transfer back to LabView) using TCP protocol.
To send data I use (a little changed) example from LabView folder (‘TCP Data Server - Touch Panel.vi’). It is possible to connect server with client. However I have a problem. It is not possible to read data sent through TCP, I have following error:
“Error evaluating registered method
'Outputs' of M-S-Function 'stcpiprb' in 'untitled/TCP//IP Receive'. The specified amount of data was
not returned within the Timeout period.
Please ensure that data is being sent to the specified port or specify a
greater timeout value.”
If I understand well data type send by LabView is different that data expected by Simulink problem. How can I force LabView to cooperate with Simulink?
Is there anyone who solve this problem?
Miro
04-27-2011 10:08 AM
Dear All,
This Topic is discussed under this Forum page:
Data transfer LabView/Simulink through UDP -
http://forums.ni.com/t5/LabVIEW/Data-transfer-LabView-Simulink-through-UDP/m-p/1517084
Regards:
Tamas
