Data saving from PIC code
Hi All
I'm having a problem transferring data from a PIC to LabView via RS232. I have 2 bytes of data per data point which are in binary. As the most significant byte only uses the 2 LSB's I'm running into those control charcters from ASCII. Also, I cannot successfully change the charcters transferred back to an ASCII No. to represent my data. It seems that the read vi doesn't like me transmitting a binary byte. I've tried the Type Cast VI but with no success. Broken wires due to data type mismatch. Any help would be greatly appreciated
(3,170 Views)
The best way to get help is for you to attach the VI giving problems so we can fix that, rather than us guessing what might be wrong in that VI we can't see.
(3,158 Views)
