Data reading problem with Read LVM
Hi
I am acquiring the pressure signals with 6 channels using LabView 7.1. The sampling rate is set at 10kHz. I am saving the data using Write LVM.  For post-processing of the data I am using Read LVM function to replay the data. When I saved the data and reopened it using Read LVM, the waveform was different as compared to when I was acquring the data.  Both images are shown in online_data.bmp and image_by_read_lvm.bmp. The Read LVM vi has also been attached. The write LVM file size was around 15MB.
I think the problem is with the rate at which read lvm is reading the data.
Any help/suggestions will be appreciated.
Pramod
(2,695 Views)
Hi Pramod,
can you upload your write vi, or one of your lvm files, which you load with the read vi?
Mike
(2,684 Views)
Hi Mike
Thanks for your reply.
Please find the write LVM file as an attachment.
As the write LVM file size is 5 MB, it is not getting attached.  Therefore I am attaching the vi code. If you need the write lvm file then can you please give your e-mail id? I need the smooth thin lined waveform instead of thick waveform. Please let me know if the lvm file is required.
Pramod
(2,670 Views)
