Data logging
how to extract a row in a excel by the help of an element of that row
Message 1 of 8
(2,722 Views)
Hi Mudit,
how is your topic "Data logging" related to your question about "handling Excel files"?
Read the row, then examine that specific element…
Message 2 of 8
(2,716 Views)
Actually i need to extract data of a patient based on a patient ID and patient password of which i have created an Excel sheet and what you just suggested i tried but it is easier to say then done i am only witnessing garbage string values not the actual data that i wanted to extract can you suggest what could be the problem
Message 3 of 8
(2,705 Views)
this is my excel sheet from which i have to extract data
Message 4 of 8
(2,699 Views)
Accepted by topic author Mudit099
Hi Mudit,
You didn't attach any VI(s), so we cannot tell you what is wrong with your VI!
I can only guess:
You try to read an Excel file using the "Read Delimited Spreadsheet File" function - which is the wrong function!
You need to use functions from RGT (Report Generation Toolkit) to read Excel files - study the example VIs in the example finder on how to use them…
Message 5 of 8
(2,693 Views)
Alternatively save your spreadsheet as a csv file (which is a plain text file) which will allow you to use the LabVIEW file IO functions and spreadsheet string to array
Message 6 of 8
(2,684 Views)
you guessed it right i used the wrong function rest i will try what you suggested thanks for your guidance
Message 7 of 8
(2,640 Views)
ok
Message 8 of 8
(2,639 Views)
