Data logging on date basis
I am working on a project, in that project i am logging data in text file, based on date. when date will change file will be change.
there is a condition , if month change than i have to delete text file of previous month one bye one from 1st to 30,31st.........
along with this query i am sending image of my logging vi
please give me the solution.............
Prashant Soni
LabVIEW Engineer
(2,811 Views)
If i well understood your problem, I think the solution can be found in the vi "check if file exists".
You're writing a file which name is based from the date of the month. For exemple june2010.txt.
You check if the file exists :
If yes, you store your datas with control of size.
If this file doesn't exists, you create a new one, with initialization.
Hope it will help you.
V-F
(2,792 Views)
