Data from excel to array
Hi, Is there a way to input a large amount of data into an array control? I have a large amount of data, which I'm trying to input on the front panel of the LabVIEW interface.
Andrea
Message 1 of 22
(8,502 Views)
Can you attach the file? That would be the easiest way for us to give you the appropriate help.
Tim
GHSP
Message 2 of 22
(8,500 Views)
If you know about Quick Drop and the keyboard shortcuts I have just what you need right here.
http://forums.ni.com/t5/LabVIEW/QD-Shortcut-Paste-to-Array-Constant/m-p/1088366
Message 3 of 22
(8,487 Views)
Spreadsheet String to Array in the string palette is the place to start.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 22
(8,484 Views)
I just installed LV2010 and I actually had to check and see if there was a new 'Import from clipboard/Excel' option.  Nope, only export.  It's a good idea although these features are almost going overboard in the name of convenience.  It's not difficult to use the LabVIEW functions to do this type of thing.
Message 5 of 22
(8,481 Views)
I have a slightly modified version of the QD shortcut which pastes the clipboard data into an existing control (edit mode of course).  Not bad, I can see the usefullness of an Import from clipboard function (ie. smarter pasting), maybe in LV11?
I use the shortcut I linked to mainly to create enums.  I can go to Notepad and quickly type the values I want for the enum, copy and use the shortcut to get a string array. A Right-click framework plug-in  converts the string array to enum and 'Bam!', much better than using the built-in method.  It is also useful for the forums, a lot of people put data in their posts, instead of typing I can copy and create an array.
You should post the 'Import' idea and see where it goes, maybe it already exists.
Message 6 of 22
(8,470 Views)
Hi, I like the Spreadsheet String to Array idea so far ... Although I don't know anything about Quick Drop and the keyboard shortcuts.
Just an additional question - Looking further into my application, I'm unbundling the array from a cluster. Can an array be unbundled to a excel field, instead of an array field? I hope I'm making sense.
Sorry, I'm not sure if I can post my code online due to policies of the agency I'm working with.
Andrea
Message 7 of 22
(8,432 Views)
Let me re-word my question ... is there any way of having an excel or spreadsheet field in a cluster? Alternatively, reading from a file would work just as well.
Andrea
Message 8 of 22
(8,392 Views)
These are explained in the LabVIEW manual.
You need to be a bit more clear. Are you actually dealing with Excel workbooks, or text files? Where is this cluster that you are referring to that has this array as an element? I don't understand what you are talking about when you say having an "Excel field" in a cluster. Please provide some clarification as to what you are actually doing or tyring to do.
Message 9 of 22
(8,378 Views)
Ummm...  Can you re-word it one more time please?
Are you wanting to take data from a spreadsheet (Excel or otherwise) and bring it into LabVIEW for further processing?
There is no particular need to manually fill a front panel control to load and process external data.  When you use the 'spreadsheet to array' type functions they read the spreadsheet file and generate a LabVIEW array that you can pass on to other functions down the line.
You can't have an actual spreadsheet in a cluster but you can have an array that represents the spreadsheet and it could be in a cluster.  This is what is confusing about your question.  Are you going from LabVIEW (arrays and clusters) to a spreadsheet file of visa-versa???
Message 10 of 22
(8,376 Views)
