Data from arduino/serial to compass plot
Hey everyone, so basically what I am trying to do is input data from an acceloremeter sent from my arduino using serial, to a compass plot, I have already done the translation from array to cluter, but when I try sending that to the vector function, it doesn't register, I've done DBL or any other format it has asked for, or I could see in the LabView help modules, I am looking for a way to solve this, see proper documentation or if anyone has any other ideas to represent IMU data I would be extremely happy!!
(734 Views)
(717 Views)
Hi cinco,
why do you need to post the same question twice (in different threads)?
  • Why do you need to convert an array to a cluster?
  • Why do you think the Compass helper VI accepts your cluster? (Does the help for this function tell you so?)
  • The Compass helper accepts two 1D arrays to theta and radius (or one complex 1D array containing the same data): did you even try to build such arrays?
  • Why do you think we can help you with images of code? (We cannot edit/run/debug images in LabVIEW…)
  • Did you try to start the example VI for the Compass helper VI? (context help -> detailed help -> Open example…)
(695 Views)
