Data from Serial
Do I need a DAQ board to read data off a serial port?
I have Labview 5.0, 16550 UART (COM 1) and I'm getting data off a RS-232
Port. The data is weak (in the 10s of microvolts).
Thanks.
-Dorian
dorian@jps.net
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,773 Views)
In general, no, you just use the serial functions in
either VISA or the serial port to read the logical
value of the serial port. The bit collecting, parity,
and handshaking business are taken care of by the
HW and serial driver.
With values this low, they will all be below the
threshold voltage and no data will arrive. If the
signal is a logical serial signal that is this weak
because of distance or poor cabling, then it would
be best to fix the cabling or whatever. Amplifying
the signal would just amplify whatever noise exists,
and the signal would be a mess.
To answer the o
riginal question, though -- yes, a
DAQ board can measure this if the board can apply
a gain or if you preamplify it.
Greg McKaskle
(3,773 Views)
Hi Greg,
Thanks for the 411. I figured out the problem (the cables).
*peace*
-DG
In article <37FF3D26.A4035DF8@austin.rr.com>,
RS-232
is weak
> To answer the original question, though -- yes, a
> Greg McKaskle
Before you buy.
(3,773 Views)
