Data coming out of a loop, how can I represent them to be similar like they were in the loop?
If I link the vi "filter 2 1.03" located in the "analysis" vi (independantly from "analysis") to the "Global" vi located in the "3 dim-graph" vi and the link this to a 3D graph, I get the graph I looking for.
Here, the "filter 2 1.03" vi is located in the "Analysis" vi and the data traverse a loop before going to the "Global" vi, located in "3 dim graph" vi.
How can I do to have the data going in the "Global" vi, like if they were just coming out from the "filter 2 1.03" vi?
Summer
(3,069 Views)
When I try to open your VIs, they come up broken. You may want to save the VIs as a development library. Open the VI >> file >> save as >> development distribution. I also cannot follow exactly what you need. Would it be possible to simply your code down to the exact problem? This will help us tremendously in giving you a solution.
Jeremy
(3,069 Views)
Like Jeremy, I too couldn't completely open your VI but I did notice a couple of for loops with outputs autoindexed. A scalar exiting a for loop becomes a 1-D array and a 1-D exiting becomes a 2-D array. If you had a graph inside one of the for loops and need to move it outside, then use an index array function to get what you need.
(3,069 Views)
Sorry, my question was not very clear. I thought that there was a problem with the loops. I used the "Index array functions" according to Dennis Knutson and it helped. Next time I will send the vis with the development distribution like you advised. Thanks a lot for your help.
Summer
(3,069 Views)
Hi Dennis,
I used the "Index array function" and it helped. Now the 3D graph is working. Thanks a lot for your help.
Summer
(3,069 Views)
