Data base from Labview Base, possible?
I would like to sent my generated testreport(.txt) into a database. So that every report from every test is stored in a Data Base.
Is this possible with LabView Base 7.1 or do I have to buy Developer suite?
How do you do this?
Regards Fredrik C
(Database newbie)
(3,508 Views)
There is an example VI which
"This VI shows how to send data to an Access database through a macro.
For more information, on Access macros refer to the Access manuals"
No additional tookits would be required.
Search for "Sending Data To Access.VI" from the examples
(3,497 Views)
With LabSQL and an understanding of SQL, you can use any database.
(3,485 Views)
You can use ACTIVE X.
(3,473 Views)
The Database Connectivity Toolkit works fine in the LabVIEW Base package.
(3,444 Views)
