Data acquisition and analysis
I have an instrument to acquire flow rates of a breathing cycle at a rate of 100 hz. I want to check if the value measured is positive or negative and keep inserting the values in 2 different arrays in either case. At the end of each cycle i want to pass these two arrays on for further analysis. These arrays should be re-initialised to zero before the start of the next cycle and then repeat the procedure for each cycle. It would be great if someone could help me with this. I dont know the frequency of each cycle since it may change with each breath and from person to person.
(2,879 Views)
You may need to provide some additional detail, before anyone can make any concrete suggestions.
How are you connecting the instrument to the computer/controller running LabVIEW? Does the instrument communicate over serial or GPIB, or does it output a digital pulsetrain or an analog voltage?
I've attached a small snippet that demonstrates one possible way to add positive values to one array, and negative values to another, but I haven't tested it
Fred Visser -- SystemLink R&D -- National Instruments
(2,848 Views)
