Data Streaming in basic project
Hello. In the attached image I would like to introduce a "Data Streaming" type function. Do you have any suggestions to add?
(3,287 Views)
If you just want to log the data to a file, then I would use the DAQmx Configure Streaming.vi to tell DAQmx to stream the data straight to a TDMS file for you.  You call that VI before you start the task.
(3,257 Views)
Thank you
(3,221 Views)
Hello. As a practical exercise, they recommend me to carry out the continuous acquisition with hardware timing of two signals and their storage using the diskstreaming technique and another VI that reads the samples acquired in the first VI, as well as their graphic representation. Thanks
(3,219 Views)
Hi Benru,
@Benru wrote:
As a practical exercise, they recommend me to ...
Who is "they"?
Why don't you follow their recommendation?
And why do you need to start a new thread on the very same topic? (After getting a good answer???)
@Benru wrote:
Hello. ... Thanks
What is the actual question in your message?
(3,215 Views)
Hello. I think I got the question wrong: what can I do to improve a basic VI project that is continuous read and write using two channels. I would be talking about continuous acquisition
(3,200 Views)
