Data Reduction and spectrogram
I Want to apply data reduction techniques like integration, differentiation windows and filters which is required,Then want to plot spectrogram, The data is large in numbers(about 2million). Please explain the sequence of functions I should apply or give some example.
(2,732 Views)
Hi shukla,
This sounds like a good plan!
What have you tried so far?
2 million samples is not so much…
First "data reduction" (whatever this means), filters and then plotting to a graph…
Again: What have you tried and where are you stuck?
(2,714 Views)
I have tried bandpass filter and STFT spectrogram VI and windowing function. But I don't know right order of their application.
(2,676 Views)
Hi shukla,
The point is: what is YOUR application (aka: requirement)?
First you need to define your requirements, then you should start coding…
(2,665 Views)
