Data Plot Error 85
Hello, I read serial data from vacuum sensor. Then i want to plot received data graph received instantly.
According to my data out, how do i choose "scan number" or xy axes values to solve error 85?
(3,922 Views)
I can't open your VI because I don't have LV 2019.
Looking at your screenshot, it looks like your PC is setup to use that crazy European comma as a decimal point.
The string you are reading as a comma as a delimiter, and a period as the decimal point.
My guess is your PC settings are being confused with the incoming data string.  Look at the format string for Scan from string.  There is a setting to specifically define a period as the decimal point no matter what your PC is set to.  Start our format string with %.;  and see if that fixes your problem.
(3,873 Views)
Thanks RavensFan for your attention. It's vi. Can you view it this way to solve the error?
Actually i added data on display screen. I should see the same data format in front panel when data receives. (Like that 4.77 x 10^-6) For this, where i should focus on VISA Read or data out in .vi ?
(3,834 Views)
Hi bestecf,
did you take any of those Training resources offered in the LabVIEW forum header until now?
Then you should have learnt about basic debugging techniques…
So the error 85 has nothing to do with plotting data on a chart.
Instead you should read the error explanation to find the problem source!
What is the content of "data out" What does ScanFromString expect?
Why don't you implement some basic error handling? (Again: basic LabVIEW training!)
(3,825 Views)
@GerdW wrote:
Hi bestecf,
Yes, I know. I want to indicate as another thing. Thanks your advices...
(3,820 Views)
I thought I was pretty clear in my message about what to do.
The format string, that string constant that goes into the top of the Scan From String.  Make it say      %.;%f  instead of just %f.
Actually, your %f was wrong because you are only trying to get one value, but your device is sending two.  Make it    %.;%f,%f
(3,808 Views)
