Data Logger
HI
I am new to LabVIEW
Can Anybody tell me what is a Data Logger and How can I use this
concept for my College project with the help of LabVIEW.
Waiting for responses. and I m sorry if this question makes u feel
angry.
(3,746 Views)
Greetings james,
I no know if it is allowed to put links to other sites or not ..
Anyway, I'll put the link and if it isn't allowed then I'm sorry and the moderators should edit the link.
Ayman Mohammad Metwally
Automation Engineer
Egypt - Cairo
(3,738 Views)
A data Logger can be defined as: An instrument that logs and/or plots one or more channels of analog or digital data.
The channels might  measure any of the following- temperature, relative humidity, light intensity, on/off, open/closed, voltage, pressure and events, etc  over time.
You can start from these two examples that i have taken from 'examples' shipped with labview.
First VI does data generation, Data logging  and second VI reads this data from the saved file.
Also, open  labview ->  examples-> go to 'search' tab and key in the words datalogging to get a list of all relevant self explanatory examples.
If you have any doubts after going through all these excercises, do not hesitate to get back and clarify your doubts.
Regards
Dev
Message Edited by devchander on 01-02-2006 02:09 AM
(3,738 Views)
Also this link should give more info
[broken link removed]
Hope this helps
Dev
(3,733 Views)
Hope this helps
Dev
Oops, I didn't know that NI produces Data Loggers !!\
Now I know that I shouldn't put this link in my previous post .. I tried to edit it but the time is expired .. Sorry !
Automation Engineer
Egypt - Cairo
(3,729 Views)
