Data Analysis Software
Hi all,  do you know if exist an already done software for LabView for data analysis?
like origin or originpro for example, but in labview environment.
I mean a basic software for plotting and basic analysis, not too much complicated.
It could be useful for fast analysis without programming every time.
Thank you! P.
(4,143 Views)
Once you use it as a standalone program, it does not matter if it is written in LabVIEW. Where does the data come from?
If you are a skilled LabVIEW programmer, you can write such a program within minutes and customize it as needs change. I do everything in LabVIEW, from publication quality graphs to 3D and never felt limited.
(4,122 Views)
Labview is a programming language and so it should be expected that there will be some amount of programming involved.  Mostly, the programming will be about manipulating the data in such a way that it can be analyzed and then displaying the results afterwards.
NI does have a program called Signal Express that can be used for quickly acquiring data from a DAQ device.  As far as I know, it doesn't have the ability to analyze the data but the acquisition portion can be converted into Labview code at the press of a button.  From there, you can use the many available analysis VIs to get the data that you need.
Edit: Signal Express does have limited analysis tools available, at least in version 2012 that I am using (Frequency, Amplitude, Statistics, etc).  Newer versions may have more functionality built in.
aputman
(4,118 Views)
Also have a look at LabVIEW NXG.
(4,099 Views)
Ok, Altenbach thank you for the reply...I am going to deep programming then, I just prefer to spend time in it instead of switching to a standalone program...Thanks, P.
(4,061 Views)
Thank you Aputman for the message...you told me almost the same message from Altenbach, that is important to learn programming at a good level. Ok, thanks. P.
(4,060 Views)
