Data Acquisition using cDAQ 9718 ,NI 9232 NI 9219 Modules and LabVIEW 2013
Guys,
Need assistance for building Data Acquisition Application using cDAQ 9718,NI 9232 and NI  9219 modules and this application will be used to measure Pressure,Acceleration and Temperature.
Below the application model planned:
1.Application should acquire data when NI 9232 is plugged into cDAQ.Please note its doesnt mean particular Sensor should be connected to particular channel number  ,any sensor can be connected is any moudles channel(i.e cDAQ can have  2 NI 9232 module plugged into it and 1 pressure sensor can be in CH 1 of First module in slot 1 and 1 Acceleration sensor can be in CH 2 of 2 module in slot 3 and its varies like this.)
2.Application should also acquire data when NI 9219 is plugged into cDAQ with all above needs,but it measure current as analog input.Please note when using N 9219,CH 4 wont be used to connect sensor,only first 3 channles will be used
3.Finally plan, application should be acqiure data,when both NI 9232 and NI 9219 plugged into cDAQ with all above needs.Please note among 8 slot ,9232 can be two or 9219 can be three and its varies like this.
Basic idea of this application should be a Modular cDAQ system ,so that can be used for both Voltage and Current Input sensor measurement.
Please provide ur views to make it done and used in future.
Let me knw for any clarifications.
(3,276 Views)
We need some programming inputs for implementing this using NI DAQ max API's
(3,265 Views)
Please be specific in the type of help you need. There are numerous examples that come with LabVIEW so that would be an obvious place to start.
(3,253 Views)
