Dashed line on a XY graph
now ok?
Message 11 of 12
(344 Views)
@Asif138 wrote:
now ok?
The OP said "I would like the white line as solid, the red line as dashed, the green line as dotted."  Your legend has Red and Green backwards (dashed means longer lines between spaces, dotted is shorter lines), but your graphs has Red and Green lines with similar appearance.  Compare with the Diagram on my earlier post.  You don't need to post a Reply -- simply look at your results and see if it matches the Problem Description and my (so-far-not-acknowledged) "Solution".
Message 12 of 12
(332 Views)
