Dashboard Server Name or IP
Hi! I´m trying to connect my ipod and Dashboard. I get: Invalid server, cannot connect to server. Check address and wireless connection and try again.
How can I get the right IP?
I've tried:
cmd ipconfig, the one that says IPv4
cmd ipconfig/all -> DNS server
In my ipod -> settings, Wi-Fi, IP Direction
In my ipod -> settings, Wi-Fi, IP DNS
plz help 😞
(3,650 Views)
Hello Leez,
I would like to shared with you the following link with a Tutorial which describes the basic steps for getting started with Data Dashboard.
Getting Started with Data Dashboard for LabVIEW
You must verify that the Server (Computer) and the Iphone are in the same network in order to establish the right connection. Another important point is to deactive any Firewall or Antivirus.
You can check the right connection between the devices using the following command:
cmd--> ping 10.10.x.x     (Iphone IP Address)
If the device (Iphone) replies all the packages, the connection is established in a proper way.
Let us know if you could solve this issue.
Regards!
Antonio S.
Applications Engineer - NI Mexico
(3,527 Views)
