Darren's Weekly Nugget 06/28/2010
A version of solution is to only scroll to the end if you're already at the end.
You can get the current scroll position, scroll to infinity, check scroll pos and compare to see if you were at the end (slightly messy, but it's a solution).
If you were, scroll to infinity again after adding the new text, else scroll back. ^^
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 23
(3,553 Views)
Darren, I've always fixed this issue by "snapping" the scroll bar to the bottom if the user moves the scroll position from earlier in the buffer to within one screen's worth of the bottom.  My logic is to turn off the auto-scrolling once the user moves the bar and keep position off until the user brings the bar within X number of lines of the bottom.  This is trivial to do with listboxes, more difficult with string controls (but still doable, of course).
Message 12 of 23
(3,542 Views)
I wondered if my excitement over my solution was a little premature. Oh well -  at least I got to play with LabVIEW for a little while today. 😃
-Randy
Nothing like a good dose of LabVIEW to cure what ails ya'.
Message 13 of 23
(3,525 Views)
Here's your max scroll position (scripting required):
17983iC3E60C08F1C51F0A
Message 14 of 23
(3,475 Views)
/Y
This is what I do and it works pretty well.  The only issue is that you can sometimes see the text box changing positions to do this test.  It looks like the text box is flickering.  You can defer panel updates to prevent this from happening (I don't know if you can defer updates to a specific control).  So defer panel updates, do the comparison, set your position, and then re-enable panel updates.
Message 15 of 23
(3,396 Views)
If you would use "quotient and remainder" instead of "divide", you would not need to go "orange" for part of the code and would lose the red dots as a bonus. 😉 (add a +1 or something slightly more fancy if you are worried about truncation)
Message 16 of 23
(3,396 Views)
That's a great Nugget Darren!
I used to get the string length and use that value for the scroll position.  I never thought of using infinity!
Now why is this not a standard option for LabVIEW?  You should be able to right-click and select "Scroll to Bottom" or similar wording.  After all, most of the time we are interested at the latest text and want to read along as new text is refreshed into the display.
Was this idea already proposed?  I should check.
RayR
Message 17 of 23
(3,342 Views)
An alternative I typically use is to append the new line (log, etc) to the beginning of the string and keep the indicator as-is, scrolled to the origin. Now the newest data is always on top and the older data scrolls off the bottom of the indicator. No property nodes needed. 😄
Message 18 of 23
(3,319 Views)
That won't work well (scroll at top) if you are looking at the entire (multipage) log text and the text is received over a serial port.  🙂
Message 19 of 23
(3,295 Views)
Yes I know, I am very late with a reaction.
Strange that those little things you use for a long time is not known (at least not in this thread) by others.
I always use a -1 as a input for the scrollpos to get me to the latest position.
You also get the coercion dot here because the input is U32
Message 20 of 23
(2,938 Views)
