Darren's Weekly Nugget 03/30/2009
Here's a quick tip when dealing with path data types.  Sometimes we have to deal with paths that have a value of <Not A Path>.  A value of <Not A Path> can be formed in many different ways...one way might be if you're trying to build a path with the Build Path function, and you accidentally wire an empty string into the "name or relative path" input.  If you want to test how your code handles a value of <Not A Path>, it's not as simple as typing "<Not A Path>" in a path constant or control.  You must operate click the little path symbol on the left side of the control/constant and change its value from "Valid Path" to "Not a Path":
If you try to type the text "<Not A Path>" into the path control/constant, LabVIEW treats that value as a relative path to a folder/file named "<Not A Path>", which is *probably* not what you were wanting to check.  The Not A Number/Path/Refnum? function is the easiest way to programmatically tell if a path value is truly <Not A Path>.
Message Edited by Darren on 03-30-2009 06:12 PM
Message 1 of 8
(7,229 Views)
That's good a tip, and reminds me of an interesting caveat that the Path to String and String to Path functions are not completely symmetric.
For example, say you have a path with a value of <Not A Path>, the Not A Number/Path/Refnum? returns true.  BUT, when you convert this path to string, and then convert it back to the path type, the Not A Number/Path/Refnum? function no loner returns True!  This intuitively symmetric conversion does not preserve the <Not A Path> value.  As Darren pointed out, LabVIEW is now treating this as a folder/file named "<Not A Path>".
So if one anticipates that a path may have been converted from strings, it may be wise to check both Not A Number/Path/Refnum? and for the text "<Not A Path>".
Message 2 of 8
(7,114 Views)
As an integrator, we've gone almost exclusively to system controls to keep things from, dare I say, "looking like LabVIEW".  Any way to do what you've suggested with the System Path Control?  I can get the <Not A Path> type into the control, but not by copying / pasting.  Run the attached VI.  Notice that when you click in the first path control, it highlights "<Not A Path>".
-Jason
Message Edited by LabBEAN on 03-31-2009 02:05 PM
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 3 of 8
(7,059 Views)
The little path symbol isn't present on the system path control, so I guess the only way to get a true <Not A Path> as the value of your control is to use the Not A Path Constant and wire it to a local variable of the control.
Message 4 of 8
(7,033 Views)
I tried this, but both yielded the same results; I got False in both the cases. Smiley Sad
The only way I could make the System path control to accept the <Not A Path> value is by placing ite constant on the BD & then changing it into a control.
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 8
(6,975 Views)
Still easier way is to place a <Not A Path> constant on the BD & change it into a Control. Smiley Wink
Message 6 of 8
(6,974 Views)
Don't forget to also check for an empty path.
Message 7 of 8
(6,962 Views)
parthabe wrote:
 I tried this, but both yielded the same results; I got False in both the cases. :smileysad:
I downloaded the VI I posted above on another machine and the top evaluates True.  To get the <Not a Path> type into the top control (versus the string in the bottom control), I replaced the System control with Modern, set <Not a Path>, and repalced the Modern with a System -- an alternate method that doesn't involve diagram mods.
-Jason
Message 8 of 8
(6,918 Views)
