Tom wrote:
> Hi,
> I have a DAQPad-1200 attached to the parallel port of a 700mhz, Win98
> machine, but Labview 6i doesn't see it as a daq device (the parallel port is
> recognized as a visa device). How do I configure it so that I can read the
> analog input channels? I'm trying to get it to read voltage levels from a
> transducer.
http://www.ni.com/support/daq/parallel/default.htm . Basically, NI s/w
doesn't support ECP mode.
Also, if the DAQPad-1200 loses power, restore its power & reboot the PC.
Otherwise the Test Resources option in MAX says "The device is no longer
responding to the selected base address". LV gives no error but no data
either.
Mark
