Daqmx Write
Hi all i have little problem with daqmx write block. I have a NI PCI 6229 and i need to write Multiple Sample and single in the same loop. What is the best way to do this?
Message 1 of 8
(3,727 Views)
i need to write on analog out port..
Message 2 of 8
(3,724 Views)
I still don't really understand what you are after.  Are you trying to write to two different AO tasks?
Message 3 of 8
(3,702 Views)
do you need to generate a waveform and a DC voltage on multiple AO channels at the same time? If this is correct, you can refer to this example.
I fope this helps!
Bye,
Licia
Message 4 of 8
(3,681 Views)
I need to write on one analog output.. I would like to write a Simple Sample or Multisample in the same loop..
Message 5 of 8
(3,679 Views)
So, you want to write to the same AO channel either a DC voltage or a multiple sample waveform based on some condition?
Bye,
Licia
Message 6 of 8
(3,675 Views)
Use a case structure...
Message 7 of 8
(3,674 Views)
That sounds like two simple DAQmx Writes using the same task.  Depending on your architecture, a simple case structure should suffice.
Message 8 of 8
(3,659 Views)
