DT9824 data aquisition
I am trying to read measurements from the DT9824, i get the following error.
Note: dt9824 driver is properly installed and I checked the devices/took measurements using the quickdaq software that comes with it.
Here is the error I receive. All dependecies are already in the respective folders and in the tree in the project but somehow its not able to initialize the driver...
Thanks!
Best,
Qutadah
(875 Views)
DT-9824 is a Digilent product. Your question is best to be posted at the Measurement Computing (MCC) - Digilent Forum
https://tmesystems.net/
(849 Views)
Data Translation was acquired by Measurement Computing Corporation (MCC) in 2015 after National had acquired MCC in 2005. After some years of lingering as an underrated division, National Instruments eventually integrated MCC into Digilent, for which they acquired all outstanding shares in 2013 after having been a major shareholder for some time.
As to the problem, it may have to do with bitness. Are you sure you installed the right Data Translation driver for the bitness your LabVIEW version has?
Rolf Kalbermatter  My Blog
(838 Views)
