DSS problems when publishing large amount of data fast
Has anyone experienced problems when sending large amounts of data using the DSS. I have approximately 130 to 150 items that I send through the DSS to communicate between different parts of my application.
There are several loops publishing data. One publishes approximately 50 items in a rate of 50ms, another about 40 items with 100ms publishing rate.
I send a command to a subprogram (125ms) that reads and publishes the answer on a DSS URL (app 125 ms). So that is one item on DSS for about 250ms. But this data is not seen on my man GUI window that reads the DSS URL.
My questions are
1. Is there any limit in speed (frequency) for data publishing in DSS?
2. Can DSS be unstable if loaded to much?
3. Can I lose/miss data in any situation?
4. In the DSS Manager I have doubled the MaxItems and MaxConnections. How will this affect my system?
5. When I run my full application I have experienced the following error Fatal Internal Error : ”memory.ccp” , line 638. Can this be a result of my large application and the heavy load on DSS? (se attached picture)
Regards
Idriz Zogaj
Idriz "Minnet" Zogaj, M.Sc. Engineering Physics
Memory Profesional
direct: +46 (0) - 734 32 00 10
http://www.zogaj.se
Message 1 of 1
(2,502 Views)
