DSP Test Integration Toolkit doesn't work with CCS4
After good experience with CCS2 & DSP Tollkit I've got CCS4 from TI.
There is no connection from the toolkit to this CCS version.
Is there is new version of the toolkit or some support ?
Regards.
Vladimir
Message 1 of 9
(4,385 Views)
Vladimir,
What Version of LabVIEW and the DSP Module are you using?
This document in the LabVIEW help may provide some help:
LabVIEW DSP Test Integration Toolkit for TI DSP
Ben Sisney
FlexRIO V&V Engineer
Message 2 of 9
(4,363 Views)
Hi Ben,
Thanks fo your reply.
My LabVIEW version is 7.1. As for DSP toolkit it's 2003 edition.
Looking for newest version of the toolkit I've not found any new version. ???
After some study of the issue I've found that the toolkit uses Active-X interface to CCS and RTDX, but I've not found any Active-X objects associated with CCS4 and it's RTDX interface. Furthermore I've got ezDSP5505 evaluation board with XDS100 JTAG interface which doesn't support the RTDX. So I think that's a deadlock and it's interesting to know about EVM5505 evaluation board. ???
Thanks.
Vladimir.
Message 3 of 9
(4,336 Views)
Hi Vlad,
Below is a link for using RTDX.  It is no longer supported, but you may find it useful.  The DSP Toolkit has been changed to a module.  The information for the module was posted by Ben in the last post.  Please take a look at those links and see if they are of any benefit to you.
DSP Communication Using RTDX
http://zone.ni.com/devzone/cda/tut/p/id/3309
Nick Keel
Applications Engineering
Nick Keel
Product Manager - NI VeriStand and Model Interface Toolkit
Message 4 of 9
(4,320 Views)
What was the resolution for this?
I'm also using CCS4 and want to automate using Labview but can't use the DSP Test integration toolkit we've used in the past.
thanks,
moises
Message 5 of 9
(3,992 Views)
Can you please tell me if there are any other toolkits available with NI which will provide me the same kind of end-user experience as the aforementioned toolkit? I am looking for some VIs which can be used to control CCSv4, for example, opening, building, and running the projects, and then showing the results using LabVIEW front panel. Also, I find, the VI which was used for opening the project in CCSv3.3 asks for a path to the .pjt file. But, in case of CCSv4, there is no concept of .pjt files for opening the projects.
I would be grateful to you if you can help me out as soon as is convenient to you.
Thanking you,
Debarati.
Message 6 of 9
(3,775 Views)
Hi Vladimir,
Can you please explain to me how I can use Active X for interfacing with CCSv4 and RTDX?
Debarati.
Message 7 of 9
(3,773 Views)
Hi Debarati,
If you read this thread again you'll find that "Ive not found any Active-X objects assosiated with CCS4 and it's RTDX interface". I left this idea but I'm still interested to know if NI offers any solution in the DSP Module for CCS4.
Regards
Vladimir
Message 8 of 9
(3,764 Views)
Please refer to the following link:
http://forums.ni.com/t5/LabVIEW/LabVIEW-DSP-Test-Integration-Toolkit-support-for-Code-Composer/m-p/1...
Best of Luck,
Jacob K
Jacob K
Message 9 of 9
(3,746 Views)
