DSP FFT problem
Hi!
 I would like to do phase shift, it works well in the following way:
 fos3.vi
 But if I try it in dsp project the same way, it can not function properly.
 fos5.vi
 I assume that the failure is in the EMB real FFT.vi or in the EMB inverse real FFT.vi.
 What can be the solution to this problem?
 Thank you for the help!
(3,523 Views)
It seems that in the Labview 8.6 DSP the EMB inverse real FFT.vi is wrong.
From where can I download a working one?
(3,518 Views)
(3,510 Views)
Is it a Real-Time project?
Do you have questions about it?  Have you already resolved it?
If you have questions....could you attach the whoel project with SubVIs? I don't have EMB SunVIs...
Peter
Peter Vago
(3,480 Views)
Hi otlm,
Are you using a hardware device with this example?  Have you added the VI to a project?  Based on your comment, it seems like you may have done this, but here is a tutorial that talks about adding the VI and the hardware to a LabVIEW project.  Do you get a specific error when you run the VI that triggers some sort of failure?  If you get an error, please post that to the discussion forum.  Thanks!
Kim W.
I use Speedy 33 DSP module. One of the attached vi-files, the fos3.vi is not a project file, but the fos5.vi was made in DSP project. Apart from this difference, the files are the same. But they can not work the same way. I do not get any error messages.
(3,472 Views)
Hi PeterV_hun!
The untitled115.vi works, but not as I wished, because I had to use some trick forcing it to work.
 It seems that the inverse FFT did not exchange but add the modified element to the array.
(3,467 Views)
