DSGetHandleSize() crashes LabVIEW
The following crashes LabVEW every time. Similar simple code with the other functions also crashes (e.g. DSSetHandleSize(), DSDisposeHandle(), etc) What am I doing wrong?
I'm using Windows 10, LabVIEW 2018, and Visual Studio 2017.
The C Code:
#include <windows.h>
#include "extcode.h"
#define DLL_EXPORT _declspec (dllexport)
BOOL APIENTRY DllMain(HMODULE hModule, DWORD ul_reason_for_call, LPVOID lpReserved) {
    switch (ul_reason_for_call) {
	    case DLL_PROCESS_ATTACH:
	    case DLL_THREAD_ATTACH:
	    case DLL_THREAD_DETACH:
	    case DLL_PROCESS_DETACH:
	        break;
    return TRUE;
DLL_EXPORT uint32_t handle_size(const UHandle h) {
	return DSGetHandleSize(h);
The LabVIEW code:
The Result
(2,750 Views)
A cluster is NOT stored in a handle. Only strings and arrays are. So it is not strange that DSGetHandleSize() fatally crashes when given a pointer to a cluster.
Right click on your Call Library Node and select "Create .c file...". Then you will see in the resulting *.c file what is really passed to the DLL in terms of C datatypes for your cluster.
It will look something like this:
#include "lv_prolog.h"
typdef struct
     int32_t elm1;
     int32_t elm2:
} RefnumType;
#include "lv_epilog.h"
uint8_t FunctionName(RefnumType *refnum)
Rolf Kalbermatter  My Blog
(2,736 Views)
