DSC stopped logging
I'm running Labview 7.1 and have up until very recently been successfully logging data using the DSC module.  The is no obvious cause for this, hence the posting.
I have the DSC module installed on a PC with an RS-Linx OPC server.  Many tags are configured and have been logging for over a year.  The tagengine is configured and launched upon PC startup.  Database is Citadel 5.
Basically, I cannot see any data beyond 8 aug 2007 when using MAX 4.1.  I have tried stopping an restarting the DSCEngine.  I also renamed the .SCF file and reloaded this into the tagengine.  Also I have added a new tag to see if that would log.   The tagmonitor shows all the tags are there and are updating.  However, when I try to add the new tag to a view in max, it is not present. I'm at a bit of a loss to understand how MAX cannot see it, and suspect this is the root of my problem.  Any help appreciated.
Mark
(7,234 Views)
try the read historical trace vi's  and see if they grab any data.
(7,223 Views)
OK.  I tried this.  The read hisorical data .vi's behaved exactly like MAX, i.e. no data beyond a certain point.  All the tags appeared to be there, etc.
I had a couple of other thoughts which I tried - also to no avail.  I looked at the services which were running, thinking thte Citadel server may not be running.  I found I had two services related to Citadel running.  Starting and stopping these seemed to make no difference, although I did not reboot the PC, a it is running a pretty critical application - although it can be rebooted if absolutely necessary.
One thing: The Citadel service said it depended on something called NIPALK, which I did not see in the services list.  Any thoughts on what this is?
(7,100 Views)
Hi Mark,
NIpalk is an abstraction layer in LabVIEW. Its really just a generic interface to LabVIEW and provides the OS access to the hardware.
Nick R
NI
(6,843 Views)
