DSC-runtime trend
hello.any body have a example from real time trend????im cant give a answer from that.please help meeeeee.
my problem is with shared variable and.......
(3,931 Views)
There is not enough information here to help us give you an answer. Can you describe exactly what problems you are having? Also you do not seem comfortable in English. There are other boards in other languages that might help with the communication.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,903 Views)
Well I do not know English .i am from Iran! I want to build a data logger . With this work. I have performed a few.but did not get any answers . I load circuit .can you help me? .The value of the loop count is not shown in the chart!
(3,875 Views)
i think .i have to build a i/o server at the project. i builded the shared variable but the box of the i/o server was empty.
(3,844 Views)
If you are looking to talk with an instruments and log the data to a file, I recommend not using DSC. This will needlessly complicate your system. I recommend looking at the Data Logging Examples in LabVIEW and use that approach. This will save you a lot of time and money in the long run.
Thomas C.
FlexRIO Product Support Engineer
(3,815 Views)
