DSC Citadel
i am working with DCS module, citadel and OPC servers
i need to know how could i have, in a VI:
- the list of all available OPC servers and by clicking on each OPC server it should browse all available variables
- then i should be able to select the variables that i need to trace, define the libraries and the path in which i want to archive each variable
- then by pressing on OK button the variables will begin to be traced in the location defined
- And if it is possible to define the frequency and the scale of each variable
In resume, i want to do an Interface in a VI in which i can choose all the variables that i need to archive without using the project explorator (which browses the servers and variables).
How could i do that ? could you help me please ?
Samer,
Samer,
(3,421 Views)
Does it mean a DCS or the LV DSC module?
Please be clear.
I think there is no VI that will list out all the available OPC servers & the shared variables, that you get to see in the NI Variable Manager. Smiley Sad
- Partha ( CLD until Oct 2027 🙂 )
(3,396 Views)
it is indeed the LV DSC module.
i need to list out all OPC available server programatically in a VI without needing the variable manager.
are u sure that i can't ?
Samer,
(3,393 Views)
I think you can programatically get only the Shared Variables, not the OPC servers.
(3,386 Views)
Yes, it is possible. I've been successful in my projects in accomplishing this.
Dynamic OPC Server Discovery and Connection Reference Example:
http://zone.ni.com/devzone/cda/epd/p/id/6341
Craig
Message Edited by craige on 01-29-2010 01:32 PM
(3,147 Views)
