DOWN SAMPLING
Hi everyone
I want to downsample the data and then convolve it with match filter. Could someone help me with downsampling . I do not i should use resample or something else.
Thank you for your help
Message 1 of 9
(6,531 Views)
Try the decimate VI, it optionally averages before downsampling. it's in signal processing->signal operation->decimate.
Good luck,
Danielle
"Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
Message 2 of 9
(6,473 Views)
but decimation and downsampling are different things? should I use decimatefor sure.
Message 3 of 9
(6,462 Views)
decimation is the process of taking one out of X samples. downsampling usually applies a low pass filter first, like a gaussian or similar. In this case, if you apply decimate with the average boolean TRUE, you apply an averaging low pass filter and then decimate. For most implementations this is good enough. For example, I have used this successfully to resize images without aliasing. What exactly is your use case?
― Terry Pratchett
Message 4 of 9
(6,455 Views)
I did the first one with upsampling, generate filter coefficent and convolution.
but the second one , I have complex input waveform .
Message 5 of 9
(6,447 Views)
this is the block I should complete.
Message 6 of 9
(6,437 Views)
I do not know, as I don't know what "complex input waveform" means. Sorry.
― Terry Pratchett
Message 7 of 9
(6,429 Views)
our teacher said i can use decimate. just assume it is complex waveform input. how can i connect complex waveform to decimator?
Message 8 of 9
(6,426 Views)
If I understand correctly, think about what data a waveform has, and how you can change it to two 1D arrays for X and Y data. you can then put them in the decimate function.
― Terry Pratchett
Message 9 of 9
(6,420 Views)
