DOS command
I want to use the system exec command. I already read one answer that is related to my problem but I´m not fully satisfied. My problem is that I want to use parameters in the command line like:
D:\MyFolder>MyApplication file0.fff -i 111.222.333.444 -r
So how do I have proceed to execute this command ?
(3,207 Views)
you must use "System exec" with following parameters:
1. Command string - "cmd.exe"
2. Standart input - the string looking like "yourDOScommand Parameters EOL"
3. Working directory is working directory.
Example is attached.
Good luck.
Oleg Chutko.
(3,206 Views)
Frederic - Munchen wrote in news:506500000008000000BBB10000-
1068850981000@exchange.ni.com:
> Thanks
I suppose that MyApplication is an application which accepts parameters on
the command line.
Have you tried to write (without quotes)
"MyApplication file0.fff -i 111.222.333.444 -r"
to the "command line" input of the System Exec command.
Check the output of the "standard output" and "standard error" from the
System Exec command t
o see if you get any messages from MyApplication.
Rolf
(3,206 Views)
