DNP3
Hi all!!
Please help me, I read 61 point Analog input from SCADA Schneider, but there 4 point that not can read the same database (analog Input), the difference between points is the DNP3 Static Object Type in g20v2,  means (Group 20 Variation 2, (16 bit Counter)) are 4 points, the 61 points the DNP3 Static Object Type in g30v1 means (Goup 30 Variation 1, (32 bit Analog Input)).
I use the poll Frozen Counter and send me the status INN when I use poll Analog Input the status send success, but in error mark a code 44201, where means "The point is not available in the master."
Please help me again.
Thanks for all
Best Regards
(2,960 Views)
Hi qz6y7q,
Please post on this board: http://forums.ni.com/t5/Industrial-Communications/bd-p/260
Our DNP3 support team will be able to help you from there.
Thanks!
Matt S.
Industrial Communications Product Support Engineer
(2,948 Views)
