DMA rate for the PCI7833R
I read the datasheet of the PCI-7833R which is the card I am using for my project. And I could not find specifications about the DMA channels, neither how many DMA channels are available neither what is the highest data rate I can send out to the host machine using the DMA channel. Actually, I only found two occurrences of the word "DMA" in the datasheet and they where in the glossary.
(3,079 Views)
One place to observe this information is in the LabVIEW project when you add a 7833 target - let me address your questions:
There are 3 DMA channels available - if you add a 7833 target to your My Computer target in a project, you will then be able to add a FIFO.  If you choose one of the DMA options you'll see there are 3 channels available (0, 1, and 2).   Check out the composition screenshot below.
The following document discusses this - I think it has the numbers you're interested in:
I hope this helps!
Best Regards,
JLS
Composition Screenshot:
Message Edited by JLS on 03-22-2007 10:59 AM
Best,
JLS
Sixclear
(3,070 Views)
