LabViewFreak wrote:
> I don't know which type of argument I have to choose for this
> argument: "pointer to an array of pointers to buffers to contain the
> appropriate strings"
There isn't any LabVIEW type which can do this. You need to write a
wrapper DLL which translates between LabVIEW types and this DLL types.
There is also no clear way in dealing with that. As it seems does the
DLL actually allocate the string buffers inside the pointer array. If
that is the case then the information you have provided is not enough.
You also need to know how the memory needs to be deallocated afterwards.
There is also no inforamtion as to how the calling application can find
out how large the pointer array should be on entry or how it will see
that the array it pass
ed was to small.
Rolf Kalbermatter
Rolf Kalbermatter
My Blog
