DLL help
Hi!
Could you help me, how to call this function from Labview? This is very important for me!
Thank you!
I'm point on the GetCameraList pointer parameter!
+++ In God we believe, in Trance we Trust +++
[Hungary]
Message 1 of 14
(5,659 Views)
1.go to block diagram
2. right click->connectivity->library&executables->call library function node
3.right click on this and serlect "configure"
4.select the dll by browsing for the dll path and seledct the required function fro the :function name" dropdown
5.hit ok
6. wire the values
and you are done
Regards
Guru (CLA)
Message 2 of 14
(5,654 Views)
And how do I configure the Parameter Type?
[Hungary]
Message 3 of 14
(5,649 Views)
Please take a look at the code.
[Hungary]
Message 4 of 14
(5,647 Views)
As posted on LAVA:
Try this code, it should get you close.
Message 5 of 14
(5,615 Views)
If someone has any good idea? Please share with me!
Thank you!
[Hungary]
Message 6 of 14
(5,595 Views)
What's wrong with the good idea he posted?
You could a bit more precise about where your problems are, so we could help you a little better...
Remember Cunningham's Law
Message 7 of 14
(5,581 Views)
After sleeping on it I realized my solution was too complicated for the way that your DLL expects the data tot be structured.  See if this works for you.
Message 8 of 14
(5,569 Views)
Nothnig happened.... 😞
pucl returns an empty string: Hex:01
[Hungary]
Message 9 of 14
(5,563 Views)
Hello!
My Problem is solved, by created a specific dll. Thanks for all!
By the way, is someone find a direct solution please post it!
Thanks again for everone!
[Hungary]
Message 10 of 14
(5,553 Views)
