DLL function called on input change
Hi everybody,
I know this is very basic; but I didn't get it by my own. I'm very new to LabVIEW and wasn't able to find a solution in the forum.
I want to call a function from a DLL every time when I press a button; but unfortunately the function is only called at start-up.
So, how can I call a DLL function on a change of some input?
I attached a screenshot. With the stuff I tried. It didn't work. Now the function is called twice during start-up.
Thanks in advance and best regards,
Chris
(3,985 Views)
Accepted by topic author ChrisTango
If you want to call anything with a button press, use an event structure with a value change event.
I would recommend that you take any of the free LabVIEW tutorials available on the site and refer to the shipping examples - Help>Find Examples.
(3,957 Views)
Take a look at the Event Structure.  That'll let you make things happen when a button is pressed.  Move your dll call inside this structure
(3,954 Views)
Hi Dennis,
Thanks that helped me out. Now I know also where to find good examples. Smiley Happy
Thank you also Natas!
Best regards
-Chris
(3,929 Views)
Thanks I got it work! Smiley Happy
(3,928 Views)
