DLL for OPC UA
Hi Labview user ,
I have a couple of question about OPC UA (i am a new user of OPC)
First question :
* I had to work with a siemens PLC and Labview  using OPC UA to communicate between each other , the issue is that when i use the installable file  i lose the OPC UA connection ,
is there a driver or somthing else missing that i should added to solve the problem?
*second question :
is there a  dll file  can we used for the OPC UA connection ?
thank you
(1,056 Views)
Accepted by topic author Haythem96
Your build application should have an additional "data" folder and in there you should find at least ni_opcua.dll. But that is not enough, this is just the LabVIEW bindings for the LabVIEW OPC UA Toolkit support libraries. And if you want to install this built application on a different computer you also need an OPC UA Runtime Installation.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QU4SAM
But this runtime also needs a paid license:
https://www.ni.com/nl-nl/shop/software/products/labview-opc-ua-toolkit.html Part Number: 785292-35
Rolf Kalbermatter
My Blog
(1,025 Views)
