DLL calling convention
I wonder what calling convention I should select at the call library node for these 2 cases of DLL
if my functions in the DLL are declared as follow;
1. extern "C" void PASCAL EXPORT my_function()
2. void __declspec(dllexport) my_function2()
thanks
(3,282 Views)
The first one uses the obsolete type PASCAL. This has been mapped to __stdcall so that is what you should put in your Call Library Node.
The second one doesn't declare an explicit calling convention so I have to make some assumptions:
1. This is not a member fuction of a C++ class.
2. You haven't defined an explicity calling convension in the compiler (such as /Gz or /Gr).
In that case, it defaults to __cdecl.
(3,272 Views)
