DLL and array of pointers to incomplete struct
I reckon this has probably been dealth with before, but I tried searching and didn't find an answer which solved my problem.
I have a function implemented in a DLL which returns a pointer to an incomplete struct.  All working fine.
I now want to write a function which passes an array to the DLL (pre-allocated in LV) and fills this array with a series of pointers to the incomplete struct (Same datatype as works fine above).
I cannot get this to work.
I have tried:
int function(struct incompletestruct *array) as a function prototype, but I get complaints of "unknown size of incomplete struct"  if I then try to reference array[value].
I have tried
int function(struct incompletestruct *array[]) as a function prototype, but LV locks up hard when I call this with "pointer to Array data" setting.
I have tried
int function (struct incompletestruct *array[16]) as a funtion prototype, but same lockup as above.
What combination of function prototype and DLL calling convention in LV do I need for this?
I'm using LV 2009 SP1 and CVI 9.0.
Shane
Message 1 of 8
(3,693 Views)
Does anybody have some SENSIBLE suggestions?
Shane
Message 2 of 8
(3,662 Views)
OK, now that the spambot reply is removed, I come accross all silly with my "SENSIBLE" comment... Smiley Surprised
I would be very grateful for help on this issue.
I want to return a reference of all USB devices found in the system via LibUSB and while my function works for a single element (giving the reference as return type) I cannot find a way to work with an array of these items.  Since I cannot pass back an array as a return value, I need to pass a pre-initiialised array to the DLL.
How do I pass an array to a DLL where the DLL expects an array of references?  How do I handle this array in the DLL?  I tried Array[] which compiles but locks LV up on me when I try to call it.  Do I need to go the **Array route?  I'm a bit of a CVI newb, so I'm not going to be annoyed if somebody points out some incredibly stupid thing I'm doing.....
Regards
Shane.
Message 3 of 8
(3,646 Views)
Accepted by topic author Intaris
I'm not able to solve the complete issue, but can at least give some hints:
* an array of pointers is an array of I32 (I guess that won't be true in 64bit any more).
* Hidden in the LabVIEW.exe there are some undocumented functions that allow to do pointer operations. Somewhere there should be a LabVIEW.h file. And just type labview as the dll-name in the call library node.
* So the complete concept would be to cast data-pointer via these build-in functions and treat the pointers as I32 to pass them inside LV.
Felix
Message 4 of 8
(3,631 Views)
Thanks Felix,
The Pointer-I32 bit I already know.  I am able to receive and return a pointer to a single object I am looking for.  It's only with arrays I have trouble.
The I32 values are opaque in LabVIEW.  I can't use them outside of the DLL, but I need tobe able to decide with LV which device is being called where and when.  As such I read the I32 from the DLL and pass it back in whenever I need it.  The I32 is not modified or otherwise used in any way in LV.
Something occurred to me this morning.... I have had problems in the past with trying to open a reference to perticular devices.. I might be causing the lock-up by opening references to the wrong devices in my system, the lockups may not be a direct effect of my assumed array problems.  In my testing, I have been trying to open references to ALL devices and this is sometimes not a good idea.
I'll give an update later.
Shane.
Message 5 of 8
(3,626 Views)
Aargh.
This is why I love LabVIEW.  The bug I had in my code would NOT have gotten past my eyes in LabVIEW.
The device I should not be opening a reference to (Don't ask me why, it is just like that...) is the first on the list of my LibUSB devices.
I tried to use a special VID and PID code to simply return EVERYTHING (0xFFFF) and this is where the bug crept in.
Using the code
if ((dev->vid == VID) || (VID = 0xFFFF))
Do something
will always try to open a reference to EVERY device.
The correct code:
if ((dev->vid == VID) || (VID == 0xFFFF))
Do something
behaves itself properly.
Bah!
Felix,
thanks for your help anyway.  Sometimes just hearing someone answer kicks the brain into a different gear which ends up solving the problem.  As such, even though your post doesn't contain the technical solution, it's getting marked as having solved my problem....
Shane.
Message Edited by Intaris on 05-25-2010 08:38 AM
Message 6 of 8
(3,610 Views)
Do something
The correct code:
Do something
That is why some C programmers reverse the comparison parameters:
if ((dev->vid == VID) || (0xFFFF = VID))
would have given you a nice compilation error to the meaning of "operand is not a lvalue" or similar.
Rolf Kalbermatter  My Blog
Message 7 of 8
(3,585 Views)
Rolf,
that's a cool idea.  I've never heard of that before.  I must remember to do this, it makes catching problems like this SOO much easier.
I have my code up and running now.  I didn't get the array part working but I simply added an "index" value to my single-device code so that I can target different devices to open a handle to.
I'll get back to the array version sometime and will post if I get it working.
Thanks for the help.
Shane.
Message 8 of 8
(3,575 Views)
