DLL Trail
Hi
I posted last year regarding accessing DLLs from LabVIEW. I've now hit a brick wall after getting the vendor's data sheets.
My main concern at the moment is that the DLL is looking for C variables of the type LONG, SHORT, INT, etc, but when creating the call in the configure window, the preview does not show these variable types. Needless to say, the whole lot crashes the instant I run it.
Is there a look up table showing compatible data types that I can get my hands on?
Any suggestions?
Yours sincerely,
Chris McCrory
Project Engineer
______________________________________________
SP Technology Limited
E-mail: c.mccrory@sp-tech.com
Website: www.sp-tech.com
Tel: +44 (0) 1382-880088
Fax: +44 (0) 1382-880099
The information in this e-mail i
s confidential and for use by the addressee(s) only. If you are not the intended recipient or responsible for delivery of the message to the intended recipient, please notify us immediately on +44 (0) 1382 880088 and delete the message from your computer; you may not copy or forward it, or use or disclose its contents to any other person. As Internet communications are capable of data corruption, SP Technology Ltd do not accept any responsibility for changes made to this message after it was sent. For this reason it may be inappropriate to rely on advice contained in an e-mail without obtaining written confirmation of it. Please note that SP Technology Ltd does not accept the liability or responsibility for viruses and it is your responsibility to scan attachments, if any. Opinions and views expressed in this e-mail are those of the sender and may not reflect the opinions of SP Technology Ltd.
(3,308 Views)
Chris McCrory wrote:
> Hi I posted last year regarding accessing DLLs from LabVIEW. I've now hit
> a brick wall after getting the vendor's data sheets. My main concern at
> crashes the instant I run it. Is there a look up table showing compatible
Typically INTs are at least 8 bits (can be 16) SHORT 8 bits (can be 16) and
LONGs are 32 bits.
You can look in the Labview docs to see what size they are. The DLL should
follow the convention
of the compiler that made it.
(3,308 Views)
For a 32-bit operating system, such as Win9x or NT, usually the
following applies:
long - 4 bytes - 32 bits, use labview I32
short - 2 bytes - 16 bits, use labview I16
int - 4 bytes - 32 bits, use labview I32
for "unsigned" integers (for example: "unsigned long"), use the U32
type, etc.
Also, remember to check if the DLL requires the parameters to be passed
as values or as pointers. Improper pass configuration can also cause a
crash.
Max
In article <93unr3$snd$1@plutonium.btinternet.com>,
"Chris McCrory" wrote:
> This is a multi-part message in MIME format.
> ------=_NextPart_000_0026_01C07EE8.6B5021E0
> Content-Type: text/plain;
> charset="iso-8859-1"
> Content-Transfer-Encoding: quoted-printable
> Hi
hit a =
variables =
> of the type LONG, SHORT, INT, etc, but when creating the call in the =
> configure window, the preview does not show these variable types. =
my =
> hands on?
> Any suggestions?
> Yours sincerely,
> Chris McCrory
> Project Engineer
> The information in this e-mail is confidential and for use by the =
responsible =
us =
> immediately on +44 (0) 1382 880088 and delete the message from your =
> computer; you may not copy or forward it, or use or disclose its =
of =
for =
may =
> be inappropriate to rely on advice contained in an e-mail without =
it =
views =
the =
> Content-Type: text/html;
> > charset=3Diso-8859-1">
Hi
I posted last year regarding accessing DLLs from =
> LabVIEW. I've=20
> now hit a brick wall after getting the vendor's data =
> sheets.
My main concern at the moment is that the DLL is =
> looking for C=20
call =
> in the=20
> Needless to=20
Is there a look up table showing compatible data =
> types that I=20
Any suggestions?
Yours sincerely,
Chris McCrory
Project Engineer
SP Technology=20
> Limited
E-mail: > href=3D"mailto:c.mccrory@sp-tech.com">c.mccrory@sp-
tech.com
Website: > href=3D"http://www.sp-tech.com">www.sp-tech.com
confidential =
> and for use=20
> by the addressee(s) only. If you are not the intended recipient or =
> responsible=20
us=20
> computer;=20
any =
> other=20
> Technology=20
> after it=20
> was sent. For this reason it may be inappropriate to rely on advice =
> contained in=20
> an e-mail without obtaining written confirmation of it.  Please =
> note that=20
> viruses=20
and =
> views=20
the =
> opinions of SP Technology=20
Ltd.
D=
IV>
> ------=_NextPart_000_0026_01C07EE8.6B5021E0--
Sent via Deja.com
http://www.deja.com/
(3,307 Views)
also note the calling convention difference between some dll's. Windows
system DLLs are "stdcall" and other dll's may be "C" calling convention.
You will have to look at the header file of the function you are calling to
determine this or try both and the one that doesn't crash is correct.
The difference in calling convention has to do with stack order and who
cleans up the calling stack.
Stu
wrote in message
news:93vr5v$63f$1@nnrp1.deja.com...
> following applies:
> type, etc.
> crash.
> Max
> > Hi
> hit a =
> variables =
> my =
> > hands on?
> > Any suggestions?
> > Yours sincerely,
> > Chris McCrory
> > Project Engineer
> responsible =
> us =
> of =
> for =
> may =
> it =
> views =
> the =
Hi
> > LabVIEW. I've=20
> > sheets.
> > looking for C=20
> call =
> > in the=20
> > Needless to=20
> > types that I=20
Any suggestions?
Yours sincerely,
Chris McCrory
Project Engineer
SP Technology=20
> > Limited
E-mail: > > href=3D"mailto:c.mccrory@sp-tech.com">c.mccrory@sp-
> tech.com
Website: > > href=3D"http://www.sp-tech.com">www.sp-tech.com
> confidential =
> > and for use=20
> > responsible=20
> us=20
> > computer;=20
> any =
> > other=20
> > Technology=20
> > after it=20
> > contained in=20
> > note that=20
> > viruses=20
> and =
> > views=20
> the =
> Ltd.
> D=
> IV>
> Sent via Deja.com
Stu
(3,306 Views)
