DLL - Pointer to Boolean
Actually, I did something wrong on the first try, but the idea with the array solved the problem.
Thank you so much for the help everyone.
Message 21 of 23
(630 Views)
@Edmi wrote:
But given that I am only using one channel, the pointers "mprValChan1-3" should be passed as NULL. That is the first question, is it possible to pass a null pointer in LabView?
In case you need it in the future, the correct way to pass a NULL pointer to a function from LabVIEW is to configure that parameter as a pointer-sized integer, passed BY VALUE, and wire 0 to it.
Message 22 of 23
(625 Views)
Thank you nathand, I'll remember that. Probably I'll use that in this program.
Message 23 of 23
(623 Views)
