All,
So I was trying to track down a bug in my code, and I noticed this.
Image As you can see the DDT and contained Waveform have different timestamps. Does this usually happen? When I convert this from a DDT to a waveform it takes the timestamp attached to the waveform for obvious reasons. Is there any way to extract the DDT information using cluster functions or something so that I can manually repair the Waveform TS?
Ken
